Abs deleted will cruise work
Old Sep 14, 2018 | 09:32 PM
ttls1ws6's Avatar
Default Abs deleted will cruise work
So I have a 2001 Pontiac trans Am that Iam putting a 5.3 with a twin turbo set up while making room on the drive side engine bay I decided to eliminate the abs so it’s gone now then I’ve seen where if you delete abs your cruise control won’t work is this true?and has anyone relocated there fuse panels if so pic please I think I’ve got it all figured but open to ideals if they look cleaner then the way I plan to thanks I first time using a form hope Iam not doing it wrong
Old Sep 14, 2018 | 10:15 PM
8.Lug's Avatar
Cruise control has nothing to do with ABS. Cruise control is all in the PCM and the PCM has nothing to do with the brakes.
Old Sep 15, 2018 | 02:56 PM
ttls1ws6's Avatar
Thanks
Old Sep 22, 2018 | 09:56 PM
ttls1ws6's Avatar
so my car has traction control on it and was wanting to also remove that traction controller off the passenger fender well I’ve heard that you can change to the non traction control cruise controller to retain cruise and change 2 cables one from petal to throttle body and the one from cruise controller under Frame to throttle body is this true or do I even need to change controller and and all info please like will plug in still work to?
Old Sep 23, 2018 | 03:17 PM
8.Lug's Avatar
I was thinking about DBW - I honestly don’t know how the cable setup works. What I originally said may also be wrong. Maybe someone else can chime in here.
