TSP ORY fitment questions
On the TSP ORY-they all bolted in perfectly with no clearance issues with 4L60E transmissions!!!! Keep in mind though that if you swap to a 4L80E trans-as I have done on 2 of the aforementioned trucks-the ORY will not work. You will have to cut, section, weld, and purchase 3" mandrel bends to gain clearance under the trans at the transmission pan, and then to get back up and over the cross member on the passenger side. It's not a big deal, but does require stainless bends, and a TIG welder..
I just hacked my TSP ORY up again this past weekend by converting over to true duals into an X pipe. I basically had to cut the merge section off, and then ran 2 separate pipes over the cross member then into the X.. Not hard work, but for someone who does not do exhaust every day it takes a while to get the angles perfect so that you don't have any large gaps to weld up.
You can also expect the headers to lose their color, or shine, immediately after installation. Both my LT & ORY have a matte bronze, or gold, color to them. They turned color immediately after the first road test and then slowly devolved to the matte bronze color they are now over several months. They are NOT rusting, but they no longer resemble stainless either. Just be prepared for that to happen. Overall, 4 out of 5 stars on quality and fitment. If you did not have to bash the underside of the vehicle I would have given them 5 out of 5.
One last thing.. Several of your plug wires are going to be in VERY close proximity to the new header tubes. I ended up buying those heat shields to protect the spark plug wires. I think I ended up using 4 of the shields. This was after I burned through wire #7 within 2 days of putting the headers on. These are what I used: https://www.summitracing.com/parts/t...gaAnxiEALw_wcB
O'reillys auto parts sells them if you don't want to buy them from Summit. Since then, no problems..
For those of you who are considering going to LT headers.. Please log your IAT temps and record them for comparison to IATs after the LT header install. I would love to see a comparison of under hood temps between LT headers and factory manifolds. I think it is safe to say that you will see temps rise significantly. Since this only a hunch on my part, I don't want to throw out any #'s. On my truck, I'm seeing IATS in the 150 deg. range while idling at a red light. I do have a CAI but, like most, it is sucking hot air from under the hood. I'd be interested to hear other peoples experiences.
I have:
SE headers
TSP offroad Y
Poly motor mounts energy suspension 3.115G
UMI Kmember kit FBS002
Fits perfect.
Worse comes to worse, get your BFH out and bang on the floor board till you get your clearance. My car has been stubborn in other areas so when it does I give it the ol' backhand and make it comply lol.
I have:
SE headers
TSP offroad Y
Fits perfect.
- replace motor mounts with stock
- try an aftermarket K
- Clearnace the floor to fit the Y
Not all cars are the same. Some have to shave material off stock K to get headers to fit while others don’t for example.
