Length of damper
Old Sep 17, 2018 | 08:24 PM
QwkTrip's Avatar
Default Length of damper
What is the length of the LS1 Camaro harmonic damper?
I got an ATI damper and the pulley is sticking too far out. Can't decide whether the damper is bottomed out or if it's a parts mixup. Engine is on a stand and I can't tighten the bolt any further without a flywheel and ring gear lock. The damper is at least 100 mm long by the amount showing.
Old Sep 17, 2018 | 09:37 PM
You might have a Gen V/truck damper which sticks out the most. Tell the parts guy the year of your car, and if you already did that, he's not paying attention. Your setup takes the "mid-length" damper. The Corvette is the shortest one of the three possibilities.
Old Sep 17, 2018 | 10:14 PM
QwkTrip's Avatar
I removed the damper so I could inspect better. The only conclusion I can reach is that it wasn't pressed on all the way. Sure seemed like it was but the numbers don't lie.
* The hub is embossed with "031", which is the correct ID number for the ATI F-body steel hub.
* Measurement from back of hub (oil pump side) to the front pulley rim is about 94 mm.
* Overall length is about 102 mm front to back.
I measured the depth of insertion from the outside of the front cover (seal lip) to the cam sprocket and that was about 20 mm. That means the front edge of the pulley rim is about 74 mm (2.9 inch) from front cover when hub is fully pressed on the crank. Those numbers seem to be reasonable based on this article,
https://www.hotrod.com/articles/ccrp...ve-swap-guide/
