Fast lsxRT porting...worth it?
https://ls1tech.com/forums/generatio...-102-fast.html
if you can afford tonys stuff ....go for it !
I do. Save your money.
Thanks for posting that link for me. Its from 2010 (believe it or not) but the info posted there is just as relevant today and the pics clearly show the improvements from the porting (opening of certain cross sections of the runners) that allow a ported intake to significantly out perform an out of the box manifold.
All of the multi piece composite intakes (FAST, MSD etc.) are pretty rough in out of the box trim. If you have the time and inclination than doing some of the obvious blending with a dremel is very effective but if you want to get the most from the swap that's a different story entirely
Its really all about your goals and the budget for the project you are working on. I cringe at the thought of installing one of these multi piece composite intakes out of the box....they just leave too much airflow potential and performance on the table.
Another big issue never talked about that I have the opportunity to see over and over is the large difference in fitment issues in out of the box trim. Some intakes are worse than others as it is a stacking of tolerances and some luck (good or bad) when these intakes are friction welded together (its not an exacting type of process). That means some guys see more or less HP than others in unported trim but once properly ported, you remove that large variable regarding how the intake was originally constructed. In fact I have returned some brand new intake cores that were so misaligned I knew there would be a good chance I might grind a hole in one side of the port wall trying to open it up to where it really needed to go to work effectively.
"Experience" is everything in most industries but especially so in specialized processes such as this. For the guys smart enough to value you that commodity you know where to find me
Russell I look forward to working with you shortly on your MMS 220 project.....thanks for chiming in this thread on my behalf
Regards,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
I think the 92 without porting is a missed opportunity as there is so much room for improvement......jus sayin
10 extra rwhp from the 2nd best porter would be satisfying enough if that is the reality, on top of the gain from an unported lsxRT intake manifold (15-20 rwhp over a tbss intake? Just guessing and hoping).
I don't even like referring to the other porter as #2 as it's not a CNC job, so the "#2" ported may be the true #1 porter on a few intake manifolds that get more time spent. This isn't to say Tony Mamo is #1 and Doug ( HioSSilver ) is #2, it was just me saying that a 2 rwhp porting difference between the 2, in either direction, would probably not be noticeable at the track through my unlocked 3800 stalled th400.
Thanks guys for the do it yourself info but I felt more comfortable sending it out for porting. I do my own tuning and exhaust systems but send porting and diff related jobs out as I know what I'm good at and not good at haha.
