05 CTS-V LS6 Valves Knocking
Old Oct 23, 2018 | 02:48 PM
TimmyDurty's Avatar
Default 05 CTS-V LS6 Valves Knocking
Howdy folks, I am new to the forum and did scour the archive threads looking for guidance, but basically my baby starts knocking (loudly) under load around 4k RPM. It is lightly modified, trans and drive train stuff, but nothing done to engine. It has nearly 100k on the odometer, but about a year ago it started this knocking.
I appreciate how impossible it is to diagnose over the Internet/forum, but basically I need some guidance on what to attack and figured, reading numerous other threads, that getting an HP Tuner and pulling the current data would be the start. It has no engine codes using my basic OBD2 scan tool, but I did have a local (and trusted) shop replace the knock sensor just in case (amongst the other mods). The guy at the shop was stumped (short of pulling the heads to take a look) and suggested I get my own "professional" tool, since I race it often.
So, I have done the small things, like de-carbonize, use 93 octane (always) and synthetic oil (always), fuel injector cleaner both Seafoam and Lucas. If the heads need to be-rebuilt, I am ok with doing some performance upgrades to the engine like new heads.
I am open to any and all suggestions including getting an HP Tuner (which one?) or another advanced scan/flash tool.
Many thanks!
Tim
Old Oct 24, 2018 | 11:32 AM
Chris Paveglio's Avatar
I had bad knocks at 4500+ rpm too (LS1 2001 TA). For years. I had done "only" an airlid. When I put on long tubes, I took it for a professional tune. The tuner (Jeremy at FasterProms) was shocked how lean it was and "how much fuel he had to add to the tables". Now it runs fantastic all the way up to 6k. I don't know if my tune was "bad" from the factory, from the 1st owner, or even just my airlid did so much to mung up the A/F ratio.
Old Oct 24, 2018 | 12:40 PM
TimmyDurty's Avatar
Thank you Chris. Are the LS1 and LS6 similar? Do you think age had anything to do with your knocking in your case? Logically speaking, something that started with higher miles would allude me to think that it was a wear item or a slowly going bad sensor, hence my request to swap out the knock sensor. As for wear items, I have read everything from tappets to cam lobe wear to pitted valves, which would make sense but hard to tell without pulling the head covers or heads themselves. If I go that far, I may as well have them rebuilt or do some performance upgrades... Anyway, for another time we can talk performance upgrades.
Do you have a preference on scan/tuner tools/software???
Thanks for the quick response!
Tim
Old Oct 24, 2018 | 01:05 PM
Different heads, cam, pistons, block details. Other than that they are identical....
Old Oct 24, 2018 | 08:48 PM
Unhappy
intake...
Old Oct 24, 2018 | 08:51 PM
Sorry I can't really say any more as what to look for. I only wanted to point out fuel map could be an issue, if maybe there was an upgrade that you did not mention. I'd go with knock sensors first too for parts. I use a wifi OBD2 transmitter and an iPhone app called DashCommand (Android version too I think). It has a lot of details (100s of sensors/data points if your car has them) and easy to use, but only reads codes it can't program. It can clear IIRC. In app purchase to unlock additional codes depending on the vehicle. I know on my car it can see knock sensors and misfires, and AF ratio. It was like $10 for the app and $20 for the obd2 adapter so a cheap way to start.
Old Oct 24, 2018 | 09:15 PM
intake...
OOPS yeah.... Good catch! I was focusing on the long block, but that is another difference for the early LS1's
Old Oct 30, 2018 | 08:22 AM
TimmyDurty's Avatar
Thanks for the responses everyone! Much appreciated. Chris, I will give the scanner you suggest a try, like you said, it's cheap way to get started.
Tim
Old Oct 30, 2018 | 08:30 AM
HioSSilver's Avatar
Knocking as in spark knock?
if that's what the knocking you hear is the check the fuel pressure/replace the fuel filter.
