An fittings for 4l60e
Old Nov 16, 2018 | 10:25 AM
Philhippy45's Avatar
Default An fittings for 4l60e
I read somewhere that you can get rid of the metal lines going to the radiator for the transmission and use rubber hoses instead and they said all you need is an fittings for the high and low pressure side of the trans and then to a cooler. My ? Is what size an fittings will fit the trans and what size hose and cooler do I get for it? It was rebuilt with a 3600 yankss just wanted to get rid of the stock lines and make it nicer looking.
Old Nov 16, 2018 | 11:53 AM
KCS's Avatar
KCS
Moderator
I went with -6AN lines and used these adapters for the trans side:
https://www.summitracing.com/parts/f...SABEgIYRPD_BwE
Going into te radiator is different, I used these:
https://www.summitracing.com/parts/f...SABEgK-9fD_BwE
