4 way & turn signal issue
Old Nov 17, 2018 | 01:06 PM
Philhippy45's Avatar
Default 4 way & turn signal issue
So I redid all my wiring in my car and marked everything with tape and got it all back together and Every thing works the lights light up car starts everything is great... But the passenger side turn signals have very low current going to them because they barely flash. I traced the wire back to where I spliced and amd thought maybe bad splice so I attached the turn signal to that a ground literally 2 from the relays and things and still the same result. 3 out of the 4 work. Also no turn signals work either. The drivers side and rear stay solid whereas the front passenger side doesnt. I'm really confused why would 3 out of 4 work?
