Idle surge and weird noise
It also has to do with the load on the engine which is a direct effect from rear gear. Especially with a 4.88, if that's indeed what it has.
Without doing the math, I've worked 12 hours today and I don't care too, at 40mph with a 4.88 gear your RPM's are obviously going to be higher than a 3.23 gear set. With the converter locked up, with a 3.23 gear it's going to load or cause a lot more strain on the engine due to load or mechanical advantage. With a deeper gear, the rear end is going to be doing more work than the engine(so to speak).
Think of it like riding a ten speed bike. At lower speeds, it's better to be in a lower gear because of gear multiplication and the multiplication of torque. If you are in a higher gear and lower speeds, the more work/force you have to do, or in this case the engine.
One way or another I would not put in a stock converter. Without knowing what cam you're running I would go with something like a yank ss3600
