Why do headers make our engines run rich or
Put your theory to rest. My car and my brothers car both ran rich when we installed LT headers. We are talking about a computerized car that makes changes based on info it receives from ins sensor. I do agree that in old school rides it may make the car run lean because you don't have the cpu making changes. Not trying to hate. Just trying to help.
O2 sensors work off temperature.
If the header moves them back to a cooler spot (not to mention the headers run cooler anyway), then the sensor picks up a cooler exhaust gas temp. Cooler, to the sensor, means more unburnt fuel in the mix, therefore rich.
The point is, the man's scanner is telling him the car is running rich after headers, but the plugs read lean.
This fits, because the PCM is tricked by cooler EGT to think the car is rich... But, as any old schooler knows, headers cause a lean condition, then add to that the PCM just might be pulling more fuel to cure the cool O2 sensors.
Yes, I understand all of you may have seen 'rich' on your scanners and edit programs after headers, but from what we are seeing here, the truth is that the PCM, therefore your scanners, are tricked into that reading.
I will ask again...
Can LS1 edit get into the PCM and recalibrate the EGT chart to compensate for the cooler O2 sensor?
Dave
I will ask again...
Dave
I forgot about that...
thats why headers can cause you to burn a valve.......
forgot it just reads rich...even though it leans you out normally...
I think I sort of got
....but not like full owned.....just enough to cause chaffing
section. The 02 sensors have to be very hot to give accurate readings, in fact
I'm told they actually contain heating elements to get them to operating temp
very quickly, even on a cold engine.
Ive been fooling around with the predater power enrichment settings.Right now Im at the settings I had when I had the stock exhaust.Those setting were PE -.48 and spark was + 4.98.Numbers looked good WOT ie O2's = .098 and no KR.
Now my numbers with thiese settings are slightly neg like before but sometimes jump positive just off excelleration and when the car has been sitting for 15 to 30 mins.
I guess I take the positive LTRIM numbers because of extra air coming into the exhaust like someone has mentioned above.
I maybe inclined to leave my setting that I have now and see how things work out and until I go and get a dyno tune because I can't get a good reading for my O2's at WOT.
Even with a dyno tune (can someone explain) how they go about it.Do they take out one O2 sensor Bank 1 say and hook up the dynos O2 ? If this is the case how can this be accurate when the O2 sensor is way down the pipe (unlike the stock location) and are we truly getting a good figure on our A/F ratio.
I need a beer right now and cook a Bison burger.
Man, Diablo predator sucks *** man...I had one and could never get the tune right. I just went to MTI in houston and got jayson to tune it for me..The diablo tune was setting my a/f to 11.5 and 3 degreees kr, pathedic. Heh my advise is to get rid of that peice of **** daiblo
See ya
To understand this reason consider MASS AIR FLOW, not pressure. The mass of air is what creates power with fuel. The object of creating power is trapping as much Mass in the chamber as possible.
Headers increase the mass through the exhaust mostly through the overlap. Engines are designed utilizing the exhaust pressure of the stock exhaust and work back to design a cam that satisfies this condition. Relieving this pressure allows more MASS to escape through the overlap. In a naturally aspirated engine this reduces the intake port pressure and subsequent less mass enters the engine as a proportion of the total sensed at the MAF sensor.
In effect the engine is fueling for more MASS then is actual needed for combustion. The O2 snesors take care of this in closed loop and you have to tune for this in Open Loop.
The headers help power in the NA condition in 2 ways:
Cool the chamber with additional flow allowing more timing and
May encourage addition MASS into the Engine, but not always.
But then again I could be wrong.
http://www.boschusa.com/AutoParts/FAQs/OxygenSensors/
If you did do it this way ignore my babble. Just thought I would throw that out there
It took me a few times of reading but it makes great sense. I know my car's rich since my plugs are so blackened.
BillC5, is a MAFTuner the cheapest/easiest way to get my A/F dialed in somewhat close? I don't want to pay for tuning but I'm running way rich. Is there a cheapo way? (ie put a resistor inline with the air intake temp sensor or MAF or something like that)
