Idle air control inlet?
Old Jan 2, 2019 | 08:21 AM
cmc#5's Avatar
Default Idle air control inlet?
On the passenger side of the TB, just across from the idle air controller there is a vacuum port that bends 90 rearwards. Is this port used by the IAC when it opens to draw air in (or more correctly crankcase fumes) or is that port just a vacuum port and it has no impact on IAC function? Another way of asking: if that port were to be plugged, would the idle air still function as expected?
Old Jan 2, 2019 | 08:27 AM
98CayenneT/A's Avatar
That port does not effect the iac. It is the clean air port for the pcv system.
