At what point does MAF size become restrictive?
Old Jan 28, 2019 | 07:59 PM
98RedBird's Avatar
Default At what point does MAF size become restrictive?
78, vs 85, vs 100, etc...
This isn't meant to be a MAF vs SD debate.
Building a 408, larger cam, TFS 245's, FAST 102/102, etc...
I am considering SD vs MAF still, but what I'm asking is at what point would the diameter of the MAF become a restriction on this motor? I imagine there'd be a difference between 78 and 85, but would 100 gain anything over the 85?
Old Jan 28, 2019 | 09:21 PM
Darth_V8r's Avatar
Moderator
Best way to tell experimentally is look at map key on engine off vs map under load. More it drops, more of a restriction the maf is.
Yes a 100 gains over a 85
Old Jan 28, 2019 | 09:46 PM
LilJayV10's Avatar
So at what point do you know when the MAF is the restriction and the intake isn't?
Multiple MAPs?
Old Jan 28, 2019 | 10:42 PM
Darth_V8r's Avatar
Moderator
You know ambient based on key on /engine off. Say your ambient is 98 kpa and under wot you get 94 kpa. The intake is a restriction. You pull the maf and you get 98 kpa under load? The maf is the restriction.
All there is to it really.
Old Jan 29, 2019 | 10:51 AM
Easier yet, put a vacuum/pressure gauge between the MAF and TB. If at WOT you see vacuum, MAF is restricting. Kinda what Darth said only done differently
Old Feb 4, 2019 | 08:19 AM
danny_6725's Avatar
I asked my tuner the same question. He recommended I go maf instead of SD unless I'm going forced induction. I went with the 85mm maf. He's a very reputable tuner in the east coast
Old Feb 4, 2019 | 02:01 PM
Darth_V8r's Avatar
Moderator
for a basic cam only or bolt ons package on a 5.7, he'd be right. but for the OP's 408 with 245 heads, no way I'd run a 85mm maf.
Old Feb 4, 2019 | 03:05 PM
Chris25's Avatar
You can get the 100mm maf tub and ls3 maf card on amazon for dirt cheap under 100$ that would be way better than the 85mm maf.
Old Feb 4, 2019 | 03:09 PM
ddnspider's Avatar
https://ls1tech.com/forums/pcm-diagn...er-setups.html
MAF's can make just as much power as SD if sized correctly. Darth outlined how to measure the restriction.
Old Feb 4, 2019 | 03:21 PM
HioSSilver's Avatar
408 needs the biggest maf you can find and likely a 105mm intake tract.
A duggy box would be optimal
