K&N CAI causing extended crank when cold?
Old Feb 1, 2019 | 06:55 PM
millennium00SS's Avatar
Default K&N CAI causing extended crank when cold?
So I decided to start up my 2000 Camaro SS tonight after sitting for more than a week. When I went to crank the car over it cranked more than a few times than normal and then fired up. It’s currenly in the negative temperatures here in Michigan and I’m wondering if the temperature and CAI has anything to do with it. The battery is not low and is hooked up to a trickle charger all winter. Any thoughts?
Old Feb 1, 2019 | 07:13 PM
A VERY cold engine. Normal
Old Feb 1, 2019 | 08:41 PM
bammax's Avatar
Perfect example of why block heaters were invented.
Old Feb 4, 2019 | 08:45 AM
WSLN 6's Avatar
Every intake is a cold air intake when there is cold air going into it....
