2002 Camaro - Time To Start Some Upgrades
Old Mar 10, 2019 | 12:24 PM
CamaroDMD's Avatar
Default 2002 Camaro - Time To Start Some Upgrades
Long story short, but due to a variety of reasons...I am in the process of parting ways with my 1969 Camaro. It's sad, but it is what it is.
For the last 10 years, my daily driver has been a 2002 Camaro SS T-Top M6 35th Anniversary LE SLP. The 1969 Camaro had been my "weekend fun car" but within the next year I plan on purchasing a new daily driver and "promoting" my 2002 Anniversary Camaro to "weekend fun car." So, I'm starting to think about upgrades for it.
Originally I was hesitant to do anything to this car because it was a rare-ish version...but they made a lot of them and the true collector cars have low miles. Mine has been driven and loved and has about 110,000 miles on it. It's in great shape, but I wouldn't call it a "collector" car when compared to some others.
The car is basically totally stock with the exception of a previous owner swapping out the original SLP exhaust with a Flowmaster (boo). I don't want to do anything too crazy to this car...but I could see redoing the intake, cam, and exhaust. I have heard the LS6 intake is a great upgrade and I'd love to throw headers on it with a better exhaust (but we have emissions here so I'll need to be careful with that).
I want to start out with something simple and small. I was thinking of a cold air intake...but the car has a Blackwing hood already with a drop in K&N filter in it. It came with the Blackwing from the factory. Is this still about as good as it gets or am I better off with an open air type element? And before anyone ask...no the hood isn't for sale. Anything I take off this car I'm going to keep because I want to maintain all the original parts.
Old Mar 10, 2019 | 12:48 PM
2kSilverSS's Avatar
The blackwing lid is about good as it gets till you have a 92mm intake/throttle body or larger. You already have a factory Ls6 manifold which is good for most mild setups just fine. I would start with long tube headers and a new catback that suits what type of sound you are looking for. Then a mail order tune and if that doesnt keep you satisfied you will want a mild cam which they are any number of choices.
Old Mar 10, 2019 | 01:11 PM
CamaroDMD's Avatar
That makes perfect sense. Headers and a catback it is then. I need to make sure I don't affect the emissions...I assume a local exhaust shop can help me figure that out?
Old Mar 10, 2019 | 01:47 PM
2kSilverSS's Avatar
Long tube headers almost always dont have emssions equipment provisions and they always delete factory converters. If you have this cant get around this then you have very few real options and most arent worthwhile. How is emmisions tested in your area? Thats usually how you decide what you can get away with and what you need to have done.
Old Mar 10, 2019 | 01:51 PM
CamaroDMD's Avatar
As far as I can tell...they just check the OBDII system and any codes. I should probably chat with a local exhaust shop...they would probably know about that. I just want to go in with some knowledge beforehand.
Old Mar 10, 2019 | 01:59 PM
2kSilverSS's Avatar
In that case an ECU tuner can turn off any related codes so they dont get seen/triggered so you can easily pass any OBD inspection. Mail order tunes are the most common way to get this done.
Old Mar 10, 2019 | 03:27 PM
wannafbody's Avatar
Just do it right the first time. Order a 408-416 stroker, square heads and LS3 intake.
Old Mar 10, 2019 | 07:24 PM
bad_408_vert's Avatar
If you are in California emissions will be most strict and having headers will be inconvenient, not to say people don’t install headers on obd2 cars in California.
Even in New York having headers plus high flow cats and a tune to disable any check engine lights, I can get inspected at any service station.
Other mods such as gears add to fun factor.
Suspension mods such as good set of shocks/springs make the car much more enjoyable. Skip shift eliminator, ls7 clutch if the car is m6 or a torque converter if a4 is also good choice.
Since your car is a slp car , most likely you have better sway bars than average z28 Camaro. It also likely came with bilstein shocks but at this point age of car, it’s time to upgrade shocks also. A nice set of tires is always great.
You can read more about this in suspension section of this site.
Old Mar 10, 2019 | 08:13 PM
jlangley's Avatar
A few questions come to mind:
What kind of budget are you looking at?
How do you want to use the car? Drag race priority? Handling priority?
Local emissions requirements? Plug -in testing only? Visual inspection?
Spend some time here going through the site. There is a ton of information available but it will take some time to do the research. Lots of helpful people here too but you need to let them know what you want to spend, what your priorities are and what legal restrictions you have to work around.
Old Mar 10, 2019 | 08:26 PM
edzsilverss's Avatar
Keep it stock....way cheaper lol...and you will still enjoy driving it...
Old Mar 10, 2019 | 08:57 PM
CamaroDMD's Avatar
I just want to use it as a street car. Nothing too crazy. Something fun to drive around on the weekends. I'm looking for a mild-moderate performance increase but I want it to sound really nice (I'm selling my 1969 396 car with full length headers, dual exhaust and a 270 cam...and I want something that sounds nice to replace it...it won't sound as nice, but I want something). So, I want to do a decent exhaust and a mild cam. Engine has 108,000 miles on it so I don't want to do too much too it. I don't want to do anything that is going to cause me an emission issue. Right now, they only due an OBDII scan in my area (Portland, Oregon)...but who knows what they will change in the future.
I don't know where I want to be on budget. I have some time to get this done. I don't want to go crazy on it but I want to do it right.
Old Mar 10, 2019 | 10:14 PM
VandykeT/A's Avatar
Longtubes and Y. Ditch the flow master muffler(always heard they flow less than stock). Port the throttle body yourself (helps throttle response) and to me the number 1 M6 mod a 4.10 gear. If your not tracking it a 4.10 will be fine and at 75mph your only turning 2k in 6th and makes the car feel 10 times stronger than the airplane gears they come with. If you want stock drivebility stay in the mid-upper 22x duration on the cam. If you have a good tuner a low 23x can drive like stock.
Old Mar 13, 2019 | 12:06 PM
Mgill's Avatar
This. I would sell the 02 and keep the 69 tho.
Old Mar 13, 2019 | 12:08 PM
Mgill's Avatar
Long tubes, ORY, 228r cam, 243 heads, 36lb injectors, tune and leave it at that. If you can get the original SLP Flowpack (aka dual dual) muffler it will sound really good and not drone. If you have an SLP loud mouth its going to sound like crap.
