1999 Camaro Oil Pan Internal Cracks?
Hi all.
Recently dropped my oil pan for an unrelated issue and after giving it a good clean I’ve noticed the interior is full of cracks. There’s even imbedded chunks of metal in certain areas.
No sign of anything untoward on the outside. No impacts or stressed areas.
Pics as follows:
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x2000/b2b5f070_c75b_4964_8684_e71a38bc8321_f42079b1d4fa461a553282fdcb5e6d4019665064.jpeg)
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x2000/0ba011c3_350d_4b30_a8f2_4f2fc21462db_a333eb7a7e63f21e01622d7b690990fcd6e4ce93.jpeg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x2000/18ad4540_58e7_4653_bce7_00a1541baf2d_fe1ada92cc31ea0b4d3c8d6f337a5bdbcfc0db75.jpeg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x2000/c8159f80_3f37_43b4_962e_32eb83928efe_cabb8b514d1011668c2feba43738f99ffaebb159.jpeg)
What do we think? Clean it up with a flap disc & dremel to see what’s what, or just scrap and buy a new one?
Many thanks,
Ryan
I believe those 'cracks' are just a byproduct of the casting process. Probably something contracting while the aluminum cools. As long as you can fill it and it doesn't leak you're good to go. However the pits and bits of embedded metal are, like stocker said, a cause for concern.
