Which Moroso Oil Pan? Drag Only
I'm trying to figure out which Moroso Oil Pan will work on my twin turbo 99 Camaro drag car. Running a BMR K-Member and manual rack and pinion. Do I stick with and aluminum pan part # 21159 or go with a steel part # 20143? I also seen on Brian Tooley Racing there is a 20141-AL but I'm not sure if it will clear at the front.
Any help or information is more than appreciated?
Thanks
Chris
Thanks
Chris
Not sure if you’ve found one that works for ya but I’m planning on buying a Moroso 21159 for mine pretty soon. I imagine that most if not all of the Moroso pans (excluding front sumps) would fit around the aftermarket k-members for these cars. I have a standard UMI one for a stock rack sitting in the box, and just picked up an engine recently. The UMI unit has two tubes running across under the oil pan while the BMR unit has just one, so if this pan fits for me it surely should for you. I’ll let you know
