Patrick
Old May 16, 2019 | 10:36 AM
Patrick Jones's Avatar
Default Patrick
5.3 extreme oil leak top rear RH Bank
Old May 16, 2019 | 11:00 AM
Check the oil pressure sender. They are notorious for rupturing and leaking.
And- Next time use an actual subject in the title line. Not your first name.
Old May 16, 2019 | 11:30 AM
Darth_V8r's Avatar
Moderator
Opsu is on left side. Right side is likely cam sensor o ring
Old May 16, 2019 | 02:52 PM
Quite so! I was thinking the oil was running to the right for some odd reason.
Old May 16, 2019 | 03:03 PM
99 Black Bird T/A's Avatar
Welcome to the forum Patrick.
Hopefully it's just the oil pressure sensor as mentioned.
