Lm7 or 6.0 swap?
But, not understanding why you can't do a modded 6.0, from what I recall the lq4 was not very expensive from salvage... parts basically interchange from what I understand. Personally, I got an Lq4 and cheap 799 heads ($125 each) from a salvage yard with 228r cam and tuned myself like you mentioned. Am very happy with it. Watch your CR, LQ4 I think had dished pistons lowering CR.. need to make sure your gasket and heads and other parts work together. Otherwise was pretty straightforward. Get your recipe and post it here on ls1tech, the rockstars here will point out any mistakes. I put my LQ4 in place of an LS1 in a trans am, same computer just tuned it with HPTuners, literally all by myself 1 man show.
IMO If you already have a 5.3 in there bought and paid for, and it's good, just build it up with boltons and run it, and as you upgrade the boltons you can verify 6.0L compatibility as you go for your future 6.0 upgrade and decide. I'd get a cam and good heads and get the CR bumped up and tune it.
