Which O2 Sensor is Which? 02 Trans Am
I've got headers so the downstream sensors are no longer in use, but it's been so long since I installed those headers, I don't even remember if I installed the longer bosch/c5 sensor... Is there an easy way to tell which plug is which?
One is quite lengthy is coming down from around the top of the trans, the other comes from up near the AC condensor and barely reaches the male plug.
Thank you!
Thanks for the clarification on the sensor length... I guess that's not actually part of my problem is it.
