Confused on PCV, quick help??
For starters I have a 2005 L33 (5.3 Alum Truck Engine) ... Topped with a LS6 intake manifold. H-C-I N/A
The valve covers and they valley cover are from the truck engine.
The valley cover is just a cover (no PCV, no vacuum ports, just a plain cover.
The valve covers each have 1 port, but no PCV valve...
I guess certain engines have a special orifice or something instead of a PCV valve???
I plan on running a PCV system with a catch can, I currently have open valve covers and capped off vacuum ports
Can I put a valve cover designed PCV valve in-line with vacuum hose or is there an "in-line" PCV valve and is it different?
Again, I have one port per valve cover and a plain valley cover,
Do I Tee the Valve covers together or pull vacuum "thru" the engine side-to-side?
And finally going back to the "special orifice" ... if that is what I have on/in my valve covers,
Do I not need an actual PCV valve? Should I run one in parallel with the orifice (if it replaces a traditional PCV valve)?
I think thats about it... I have a decent understanding of the workings of a PCV in general, I just have a generation mix-up of parts and am ignorant on some of them,
I appreciate the time anyone takes to decipher this.
P.S. Is it bad to drive with just open valve cover ports (no PCV system) while I figure this out? Like are crankcase gasses "trapped" or does it just have potential to make a little "blow-by" mess?
Thanks again
The pcv on that engine is built into the drivers side valve cover. The spot where the vacuum line goes will have a raised round section which is to accommodate the pcv underneath. That started in '04 I think. When that valve gets gummed up you'll see an increase in oil consumption and may see some oil smoke from the tail pipe. Every so often you should pull the cover and scrub it out as well as possible to keep everything working right. If you do decide to run a catchcan that's the vacuum line that you want to tap into.
That should answer some questions but the ls6 intake has a different pcv location. I seem to remember a catch can isnt as important on a ls6 because of its pcv design. That picture should give you an idea of valve cover to valve cover routing though and how to get it to the t/b and intake manifold. These use a inline pcv valve, you still need a pcv with a catch can. It looks like a mess under the hood of an fbody but the pcv system is super simple once you learn where everything is going or supposed to go.
Basically just wondering if I need to T my valve covers together or am I pulling "thru" the engine... and ... Do I need a PCV Valve as well as the factory orificed valve cover??
