Proform locking header bolts
Old Jul 15, 2019 | 07:16 PM
DirtyMan925's Avatar
Default Proform locking header bolts
I’m in the process of installing LT on my 05 CTS-V. I ordered proform locking header bolts and the instructions say they need torqued to 28ft-lb Stock torque is 18ft-lb. 10 extra seems excessive it also says that vibration will tighten them so there is a chance it can increase even higher. I don’t want to end up in a situation where I’m snapping bolts trying to remove them. Has anyone used these before? I was thinking of splitting the difference and going to 23ft-lb but I’m nervous going heavy because of the aluminum heads. I can call proform tomorrow but it’s finally tolerable weather and comfortable in the shop I would like to just keep rocking and get this buttoned up.
From the website
Each PROFORM Grade 8 Header Bolt is permanently assembled with a pair of special washers. When the bolt is torqued to 28+ ft-lbs, the washers super-hardened external teeth bite into and grip the bottom of the bolt head and the top surface of the header. After being self-locked in this manner, any bolt-loosening rotation is blocked by a wedge-locking action created by the washers interfacing, matching cams. Its an uphill climb: vibration that might ordinarily loosen the bolt actually increases the wedge-locking tension, securing the bolt even more. Because this simple wedge-locking method uses tension instead of friction, contact with oil actually facilitates the wedge effect. When changing headers, PROFORM Header Bolts can be untightened with a normal wrench, lubricated, and reused.
Old Jul 16, 2019 | 01:20 PM
Just to follow up, I spoke with a tech at Proform and he said as soon as you feel them cam over (around 20ft-lb) they are good to go.
Old Aug 3, 2019 | 10:27 AM
Bspeck82's Avatar
Never had a problem with normal gm header bolts....
