Replacing spark plugs...
Old Jul 28, 2019 | 07:25 PM
curtisad's Avatar
Default Replacing spark plugs...
How do you guys go about removing the last two spark plugs on the passenger side? Do you go from the bottom or do some stretch Armstrong thing from the top?
Old Jul 28, 2019 | 07:44 PM
Deguila's Avatar
Pull plug wires off each coil. Remove bolts holding coil rack, lift whole rack off the valve cover. Plugs should be reachable at this point.
Old Jul 28, 2019 | 07:48 PM
curtisad's Avatar
Oh ok, thanks.
Old Jul 28, 2019 | 07:59 PM
Majestic9C1's Avatar
I can get 7 plugs from the top and the back passenger side I do from the bottom
Old Jul 28, 2019 | 11:38 PM
LilJayV10's Avatar
This.
I also take the coil packs off, helps with the others from the top.
Old Jul 29, 2019 | 06:36 AM
ddnspider's Avatar
Also a 1/4" ratchet with a 3/8" adapter for the spark plug socket will help make it easier to get the socket/ratchet on the plugs.
Old Aug 3, 2019 | 09:27 AM
BandDirector Blk98ZM6's Avatar
I climb in and put my knees on the battery and go after the last 2 plugs on the passenger side from the top. Yes, remove the coil packs if you have a '98, or if you have '99-'02, removed the front coil pack bracket mounting screw, loosen the back one, and just slide the whole bracket of coil packs up and out of the way.
Old Aug 6, 2019 | 06:28 AM
NoSmokies's Avatar
I just replaced plugs and wires on mine. Take the time and make some room for yourself. I popped the heater core hose off the firewall and pushed it out of the way. Took the dip stick out. Remove the coil pack bracket (this took me a little time as the last 10mm bolt in the back is a little tricky). Then you'll have enough room to get down in there with your spark plug socket and a few different extensions. I also found it easier using a flex or swivel head ratchet.
