Running a distributor on an LS
Don't know if it would pass tech in your venue.
Use a LARGE HEI style cap and distributor, install 8 motorcycle coil on plug coils inside.
remove the shaft and bottom of base, Use a micro-squirt inside to drive the coil packs..
Wrap the wiring and use a CPS off the Flywheel.
Drill hole in timing cover and run a bolt up into the base Look at a old Buick to see what it should look like.
You can feed the cam position sensor up though the hole for the old shaft.
I saw it used to make a old rod look traditional and hide the ignition.
