5.3 map stuck at elevation (96 kpa here)
Old Aug 22, 2019 | 09:51 AM
THE CALIX's Avatar
Default 5.3 map stuck at elevation (96 kpa here)
I have a gen 3 5.3 ls with a 231/242 .600 cam using a holley terminator x max,,was doing fine till I got on it and it died.. looked at my sensor gauge and its stuck at 96 kpa I've tried everything.. grounds, running through wires, changed sensor,, nothing is working any help?
Old Aug 30, 2019 | 04:28 PM
LilJayV10's Avatar
you mean your MAP kpa is 96 regardless if its KOEO or cranking? Can you post a log?
