Intake manifold upgrade question
Old Sep 26, 2019 | 02:08 PM
xxbiodavexx's Avatar
Default Intake manifold upgrade question
I have a 2000 Pontiac trans am with a BBK SSI intake manifold. I’m looking to get a new intake manifold because mine is cracked. The throttle body is only 85mm. I’m wondering what I’ll need to go to a 92mm or a 102mm. I know I’ll need a new throttle body. Will I have to get a new maf sensor? Will I have to get the car retuned? Can I use my BBK fuel rails with a new intake?
Old Sep 28, 2019 | 12:04 AM
brandon6.0's Avatar
Something like a fast 92mm intake with matching rails and tb would work awesome! U can even try the aluminum ebay inatkes. U can get a intake, rails, and tb for around $550
Old Oct 2, 2019 | 06:45 AM
99 Black Bird T/A's Avatar
The fast 92 and a quality 92 mm TB would be a nice upgrade.
I'd pass on the eBay aluminum intakes generally speaking.
Old Oct 2, 2019 | 03:08 PM
jaxcam02's Avatar
Fast intakes are nice but, the Dorman LS2 intake is a pretty nice comparble intake with a 90 mm neck and will fit a 90 mm TB. It supposedly uses the FAST bottom plastic welded to the Dorman upper. I had to smooth the runners before install but it was easy. I love the set up because it maintained my OEM fuel rail.
Old Oct 2, 2019 | 03:23 PM
imma_stocker's Avatar
What cam do you currently run and are you willing to change it out?
Street car? Track car? Both?
For overall performance I did like FAST 92/92 setup with a big cam. Made plenty of torque chugging along at low rpm and pulled hard at higher rpm where the cam woke up.
