Harmonic Balancer bolt
If you look at the list of fasteners on some of the newer GM engines that are supposedly TTY, you'd raise your eyebrows.
We're talking fasteners that only see about 35 lb/ft of torque, total.
Methinks GM is just trying to sell extra bolts.
Oh, and just for the record: I HATE TORQUE TO YIELD BOLTS. A bunch of wasteful bullshit, if you ask me.
The '90s roll around, and suddenly we start seeing these one-time-use bolts showing up.
ARP bolts can be reused many times.
TTY bolts are a budgetary choice for the OEMs.
Bolts don't have just one possible torque value. There are different torque ranges depending on how the bolt is used. There are low torques, standard torques, high torques, and even other special torques. Tightening the bolt causes it to stretch so that the threads lock in on each other. The more torque, the more stretch, and the tighter the threads lock in.
"Low" torque produces the least amount of bolt stretch. It is used only in special circumstances when you want lower clamping force for some reason.
"Standard" torque stretches the bolt more and is the usual torque spec you see documented. Most parts on the engine are assembled with standard torque, and the bolt can be re-used.
"High" torque is even tighter (by a significant amount) and the threads are stretched even more yet. It is used when there are large forces on the bolted joint and you want to make damn sure the clamping load doesn't relax and nothing pulls apart. An example would be major structural members of a tractor frame.
The GM damper bolt is made of a material that allows a lot of stretch and locks in the threads really tight. ARP uses a different material that doesn't stretch as much and can be re-used. But ARP likely has other tweaks to the bolt and washer dimensions so that the joint is good and won't loosen. Bolted joints is a much deeper topic matter than most people realize!
It's better for the OEM's to use a low initial torque value and degrees instead of JUST a flat final torque value.
It has a whole of lot things taken into consideration like prep, temp, lube, etc. It's easier to replicate a consistent clamp load based off a low initial TQ number and degrees because they know the elasticity of the bolt and the stretch of it's clamp force.
For anyone that says that stock TTY bolts are junk and should be changed out....well i guess all the people that are making ridiculous power on stock bolts are wrong.
"High" torque is even tighter (by a significant amount) and the threads are stretched even more yet. It is used when there are large forces on the bolted joint and you want to make damn sure nothing pulls apart. An example would be major structural members of a tractor frame.
