Which intake manifold
With the FAST intake, you will require some additional parts. You will need gaskets FST-146203-8, a fuel rail kit FST-146032-KIT, and line kit FST-54028-KIT. Running a stock 3 bolt throttle body will require adapter FST-146029-KIT.
The MSD will require additional parts and modifications. You will need to grind down the upper bolt head and boss on your water pump. Or you will need to buy an LS2 ADO-252-846 water pump. Running a stock 3 bolt throttle body you will need the MSD-2709 adapter and throttle cable bracket MSD-2707. You will also need the MSD-2721 fuel rail kit and quick-connect adapter fitting HLY-534-211.
If you plan to stay stock compression the cam is too big and will be a turd.
That cam will want to shift at 7800. So again, if you do not plan to rev that high, go smaller. If you do plan to rev that high, get your compression up and run the Msd.
I'm assuming this was from the low stock compression and the stock head/truck intake manifold combo. The results were fairly interesting either way.
I assumed it would carry much farther since I've had smaller cams carry out another 700 RPM.
I have 2 builds going on right now, both looking to make power over 7k, both using smaller cams than this one.
We used a custom short runner intake once that had been spinning to 8600, and put a throttle body adapter on it and a 78mm throttle body.
Power fell off 2000 RPM sooner. Runner length isn't the only factor.
With that being said, has anyone used the new Holley 4150 split intake yet?
$500 with rails seems like a decent price. I'm STRONGLY considering one for my corvette.
Holley will sell you the intake with rails, elbow, and throttle body for $800.
On my current setup, the truck intake is flat from 6800 to 7200 where I shift, and power still isn't falling off.
It looks like it would be a decent intake for a high RPM N/A setup with a 4150 TB.
For an LS1 346, I don't love it.
If it were cut on a 110 it would be better for the low compression and bring the IVC down to make more midrange. Otherwise, it's a pretty late IVC for a 3.622" stroke. Would work better on a street driven 383.
And guess what, you don't have enough cam for 7800.
This is just a bad combo all around.
