Leaking header question
I have a machinist straight edge to check them. You can also buy a good quality level from Menards/Lowes/Home Depot that will work pretty well. Even a good quality counter top is usually level enough to tell if there is a problem.
Stock MLS metal gaskets, stock bolts. Done.
IMO, there is no need to run really expensive or fancy gaskets and bolts. The stock stuff is superior to most aftermarket stuff out there.
Just my .02
Best, with headers, to use gaskets that are long-term flexible and pliable enough, to deal with things that move and don't stay put. They're not the same as manifolds at all, and the same gaskets don't always work the same.
Never had much luck with fancy bolts though... I just have regular old Lowe's stainless ones on mine. The problems I've had with headers over my lifetime haven't really included too much bolt failure, or even bolts that backed themselves out. IMO the "locking" bolt systems are just an expensive solution in search of a problem best solved at its source.
