sensors on the back of ls1
Old Jan 25, 2020 | 06:51 AM
jlangley's Avatar
Originally Posted by JStock1225
the motor came from an 05 corvette. As far as I know 06 and up are 58 except Trail Blazers and got. Anything pre2006 should be 24.
Perfect! I believe 06 corvettes were the first to get the 58x/4x, most others changed for the 07 model year.
Old Jan 25, 2020 | 08:44 AM
01CamaroSSTx's Avatar
The knock sensors are under the intake manifold on the Gen3 LS engine. Since your swapping over to LS2 or Gen4 the knock sensors are mounted on the sides of the block. You will also be needing a knock sensor extension harness and it can also be purchased through Texas Speed.
Old Jan 25, 2020 | 12:04 PM
JStock1225's Avatar
i haven’t torn down the ls1 yet. I wonder if the Ls1 sensor is the same thread pattern as the hole in the side of the block? There are 6 motor mount holes on each side of the block. I can just use a spare hole on each side for the knock sensor?
Old Jan 25, 2020 | 12:29 PM
RonSSNova's Avatar
They will fit the extra motor mount holes. There is only one on the pass side which is usually the batt ground.
Check depth of the holes. I think they are a little short for the sensor. Just to be sure
Old Jan 25, 2020 | 03:51 PM
jlangley's Avatar
LS2 corvette knock sensor locations. Use these holes but you have to drill and tap them to the correct size and use the LS1 type sensor.
Old Jan 25, 2020 | 05:28 PM
JStock1225's Avatar
thanks. hopefully it all goes smooth. I guess ima get them out of the ls1 tonight and give it a shot.
Old Jan 25, 2020 | 05:30 PM
JStock1225's Avatar
Originally Posted by jlangley
Attachment 708773
ok thanks for the info! Hopefully it all goes good
Old Jan 25, 2020 | 05:39 PM
If you do have to drill and tap its pretty easy to do.
Old Jan 25, 2020 | 07:30 PM
JStock1225's Avatar
Im pretty sure my dad has a set. I'll have to see if i can find it. There's just something about
not being about to reverse it if you screw up that's always made me nervous about it lol. Thanks for the picture and info.
Old Jan 25, 2020 | 09:14 PM
jlangley's Avatar
What size drill and what thread tap?
Old Jan 26, 2020 | 10:55 AM
It's an M10 X 1.5 and I purchased it from O'Riely's. I don't remember what drill size to use but it will tell you on the kit.
Old Jan 26, 2020 | 11:01 AM
  #32
JStock1225's Avatar
on the driver side did you mount in the same place? or use a motor mount hole?
Old Jan 26, 2020 | 01:42 PM
  #33
I drilled and tapped on the boss located behind the engine mount on the drivers side of the block down by the pan. These images are of an LSX block and not to be confused with standard LS blocks.
Old Jan 26, 2020 | 03:19 PM
  #34
jlangley's Avatar
These are the factory locations for the knock sensors on the LS2
Attached Thumbnails sensors on the back of ls1-photo4.jpg   sensors on the back of ls1-photo488.jpg
Old Jan 27, 2020 | 04:49 PM
  #35
JStock1225's Avatar
oh ok! thanks man I get what you mean now.
Old Jan 29, 2020 | 06:17 PM
  #36
JStock1225's Avatar
Just making sure these are the places to mount the ls1 knock sensors?
Old Jan 29, 2020 | 06:32 PM
  #37
Old Jan 31, 2020 | 02:53 PM
  #38
5.7stroker's Avatar
This is the ls1 and I’m transferring them from. The vacuum line that is broken goes from the throttle body to both valve covers. But on my new motor I do not have a fitting on the passenger side valve cover. How souls you guys run this?
Here's a picture of the factory line that runs to driver side valve cover.
If that is broken, you can run your own 3/8 tubing to the driver side valve cover that contains a 90 deg hose barb into a grommet.
DORMAN 42056 pcv valve grommet O’Reilly Autoparts
Watts Nylon Hose barb A-295 3/8 in ID x ¼ in MIP – Home Depot
I had this setup, but then I went all out and shaved the valve covers and relocated the coil packs. In doing so, I welded AN bungs onto the valve covers and ran my own vacuum lines. You can also buy a valve cover that has the fitting but that's more $$ than welding in the bung.
https://ls1tech.com/forums/generatio...look-good.html
Good reference image from Zlow28:
Old Feb 4, 2020 | 05:23 PM
  #39
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Hi guys! what are the sensors on the back of the ls1? I know the oil sending unit, but there is a sensor on the back of the intake and one just below the intake. The motor is from a 2002 camaro ss. Im doing an ls2 swap and im running into alot of trouble with sensor swapping. Sorry about the low quality post, im at work and trying not to get behind. Thanks to whoever reads this!!
Jason
Cam sensor. Its in the middle of the motor of course. Oil# switch is slightly to the right of it (driver side). Don't forget about the knock sensors also.
Old Mar 15, 2020 | 02:18 PM
  #40
JStock1225's Avatar
awesome thanks!!
