porting MAS on an A4
Old Jul 15, 2004 | 10:37 AM
badmfkr's Avatar
Default porting MAS on an A4
I heard not to port the MAS on the A4 car it messes up the shifting of gears.
anyone here port there A4s MAS.
Thanks
Old Jul 15, 2004 | 11:42 AM
MyLS1Hauls's Avatar
Its a worthless mod nowadays that LS1Edit/hp tuners is out. It was just used to trick the PCM.
Old Jul 15, 2004 | 04:22 PM
Cheatin' Chad's Avatar
MAS=MAF?
P orting the Mass Air Flow sensor ends is generally considered a bad idea for an A4 car because the MAF tends to report a lower load condition than actually exists. This in turn will increase the chances of transmission failure due to (I believe) slippage.
I don't know that the tricking of the PCM has to do with the MAF.
People did modify the IAT sensor to get more timing.But that's not the MAF.
Old Jul 16, 2004 | 09:53 AM
MyLS1Hauls's Avatar
Originally Posted by Cheatin' Chad
MAS=MAF?
Its a known fact that porting the MAF/MAS tricks the PCM into feeding more timing. Whenever the PCM sees lower load, it increases the ignition timing. It also creates problems with the LTFTs.
Old Jul 16, 2004 | 04:57 PM
NightHawk's Avatar
Thanks
Not a good idea...just pull the screen and leave it the hell alone.
Old Jul 16, 2004 | 05:13 PM
PREDATOR-Z's Avatar
So how about aftermarket MAFs like Granatelli.
Old Jul 16, 2004 | 05:21 PM
ddelallata's Avatar
I still can't figure out the drawbacks to descreening an MN6 car. Everyone just says not to do it , but doens't offer an explanation. I know that on the A4 cars the MAF reading is used to adjust the trans line pressure but someone please post what happens on a Manual car. I descreened mine a few weeks ago and my car seems perfectly fine. My A/F meters on the A-pillar still give the same readings as before. They go from rich to lean as they did before without a tendency to stay in one particular area.
Old Jul 17, 2004 | 11:57 AM
MyLS1Hauls's Avatar
Granatelli MAFs are junk IMO (no offense to JR)...absolutely unnecessary with LS1edit/HP tuners. They have screwed up airflow curves programmed into them and are a pain to tune.
There is nothing wrong with descreening a MAF. Thats different than porting it. Mines descreened, as are the new LS6 MAFs.
