So I got my MSD atomic intake in today...
See the injector sits way up in there. Ls1 injector with ls2 rail and msd supplied rail spacer kit.
I touch that area up a bit when i port them. There is usually some flashing from the molding process around the edges where the gasket goes. I smooth that up because it cuts that silicone gasket if you dont.
Unless the spray pattern doesnt come into contact with the pocket and positioning the injector higher up can improve fuel atomization?
Ecu calculations are based on the fuel evaporating off the intake valve, which also serves to keep the intake valves cooled.
Long winded way to say that the effect of the injector port and angle is most likely to impact you during transitions.
