Gen III Cam and Crank Position Sensors
Can these sensors be removed and then re-installed without messing up anything related to the PCM? I simply want to remove them for painting my block then, re-install, not replace, but dn't want to create a problem doing so....
Tia,
Tennsmith
Tia,
Tennsmith
Most definitely. I would probably out a new O ring on them though. The cam is a -113 ( I think ) and I think the crank is the same I've heard. I'd go to O'Reilly's as well , from my experience they have a pretty good selection.
