Magnaflow or TSP catback
Also, which would you do? Price is about same but I can get magnaflow from summit with free shipping.
You wouldn't happen to know if the intermediate pipe is 3" ID or OD where it goes on y pipe would you?
That makes sense, the SLP LM pipe fit over it, tight fit but it fit.
Edit: Checked their website. Looks like they updated it with a drivers side hanger. I had one of the first 3" systems in early 2017 I believe. They probably updated it when the 3.5" came out. That's what i'd get if starting from scratch.
I'd recommend a Hooker Maxflow with a single outlet for your car. But they no longer make the 22" muffler I have on my car, and the 14" might be a little loud for your setup.
To me the TSP catback has a unique tone to it and none of the typical rasp most fbody exhausts have, even with an off-road y pipe. I had the magnaflow for 7 years and liked it, but over time it seemed to get a more empty sound. Although the mufflers are a very similar design, the TSP is noticeably louder, but not too loud IMO. My car has a heads / cam 6.0 with a 4000 stall and no cats, and the exhaust isn't too bad when cruising around town with the converter unlocked. Once you get on it though, this exhaust really screams.
I tack welded the driver side tailpipe to the muffler to keep it from moving, which it seemed to do quite a bit no matter how much I tightened the clamp. If that has been updated then it's an easy decision to get this exhaust.
OP I see you're not too far from me, so if you want my old magnaflow you can have it for free if you're on a tight budget. It's just sitting in my shed taking up space.
iirc, the mag had its own mounting hardware that replaced the stock stuff.
