Electrical issue
Old May 29, 2020 | 11:08 PM
occhevelle's Avatar
Default Electrical issue
I've been searching and trying to figure it out but no luck so far. I have a 98 ls1 swapped in my chevelle. For the past few months it won't start after sitting for a few hours. If I jump it and drive for as little as a minute or two and turn it off it will re start no problem. I got a new battery and no change. I'm guessing there's something drawing/draining? Could it be alternator? Any ideas? Thanks!
Old May 29, 2020 | 11:10 PM
Does the starter spin it or act like a dead battery?
Old May 30, 2020 | 12:32 AM
occhevelle's Avatar
Good click, no starter. Doesn't try to turn over
Old May 30, 2020 | 07:06 AM
B52bombardier1's Avatar
Bad battery cable / connector. Get your battery "load tested" at an auto parts store after charging it up on a charger. Yes, a bad diode in the alternator rectifier could be blown thus allowing battery power to drain so get it tested at the parts store, too.
These should be free tests.
Rick
Old May 30, 2020 | 04:39 PM
occhevelle's Avatar
Thanks for the replies. Also, While checking the wiring I did several years ago I saw this in line with the alternator. I assume something is supposed to be connected to it?
Old May 30, 2020 | 04:40 PM
occhevelle's Avatar
Old May 30, 2020 | 07:52 PM
Hard to tell from this angle but could that be the two-wire connector for the F & L terminals in the top of the alternator? Do you have something plugged into the top of the alternator?
Rick
Old May 30, 2020 | 08:29 PM
occhevelle's Avatar
Yeah I have the normal pigtail plugged in on top of the alternator
 Michael S. Palmer
Old May 30, 2020 | 09:49 PM
HappySalesman's Avatar
Plug doesn't look like anything that would fit an LS alternator. Almost looks like an ATC fuse holder. Any idea where that red wire goes to? Battery?
Old May 30, 2020 | 10:59 PM
occhevelle's Avatar
I thought it may be a fuse holder too, but not sure how I would be functioning without a fuse in there. The harness is from PSI. There is a red and black wire going into white plastic connector. There's another larger gauge red wire that connects to the alternator and I think goes to the battery
Old May 30, 2020 | 11:17 PM
pdxmotorhead's Avatar
I only see one wire in the connector?
And whats that splice next to it.. it almost looks like someone bypassed a fuse-able link..
Old May 30, 2020 | 11:39 PM
occhevelle's Avatar
Bad picture - there is a red and black going into it
Old May 30, 2020 | 11:41 PM
occhevelle's Avatar
Old May 31, 2020 | 06:49 AM
Windshield wiper motor or washer pump connector for an A-body???
Rick
Old Jun 2, 2020 | 11:05 AM
Definitely doesn't look like any connector for an LS motor.
