Correct Y-Pipe Size for Firehawk?
Old Jun 17, 2020 | 08:09 AM
davep_96's Avatar
Default Correct Y-Pipe Size for Firehawk?
I recently purchased a 2000 Firehawk and am looking at installing LT's and an ORY. Does anyone know what the correct Y-pipe size would be to mate up to the Firehawk Dual/Dual? Since the Dual/Dual is a 3" system, I would think I need a 3" x 3" ORY, but looking underneath the car it looks like the I-pipe may neck down before it connects to the factory Y. Most aftermarket Y's seem to be 3" (collectors) by 2 3/4" (OEM Y-to-I connection), so I'm confused as to what the actual I-pipe inlet size is on the Firehawk Dual/Dual. I want to keep the Dual/Dual for now as I like the tone and so I want an ORY that connects to the factory I-pipe. Car currently has the factory manifolds and factory Y. Thanks in advance for any help on this.
Old Jun 17, 2020 | 10:41 PM
wannafbody's Avatar
A lot of catbacks used a 2.75 necked down section at the front to mate with the stock y pipe. Probably have to pull it off and measure.
