04 GTO Strange Overheating Issue
Old Aug 20, 2020 | 07:35 PM
Danspeed1's Avatar
Default 04 GTO Strange Overheating Issue
Hello,
Let me start by saying in general this is the strangest, quirkiest car I have ever owned. I don't even know where to begin but let me give you a quick overview of what I am experiencing.
2004 GTO w/ Full exhaust and Intake, otherwise stock. The car was owned by my best friend previously but sat for nearly 5-6 years prior to me purchasing. On the first week the radiator opened itself up at the seam. I purchased a 3 core aluminum radiator on Ebay to get her back on the road quickly. I drove it for a couple of months during "winter." It always ran warm but was never a problem. Around April it began overheating when I would get on it. I replaced the thermostat first with a 180*F, and next with a 160*F. The overheating got worse. Next I replaced the coolant cap. Then I pressure tested the system and it held 25psi for just about 20 minutes.
Idling in the driveway it stays at about 175. The minute I begin driving it the temperature creeps up with no end in sight slowly. It will continue all the way up to 220 which is where I cut it off. Both the fans are running full blast as well as the heater. I've had this thing up in the air to "bleed" it for air about 6 times already... no change.
I'm really frustrated with this car. This seems like something so stupid and simple, yet its holding me back from enjoying it.
DG
Old Aug 20, 2020 | 08:31 PM
Pulse Red's Avatar
Probably not much help but I have an 04 Monaro that I purchased new, so basically the same car minus whatever Pontiac requested Holden to change (would love to see a full list one day) and the only issue it's had is the radiator leaking.
​​​​​However, my car sits around a lot as it's rarely driven and then only on the street now, so I wasn't surprised. I usually supply my own parts to my mechanic (for all my cars) but with this, I was told sternly to only use a factory radiator as a replacement and specifically not eBay etc radiators. Unfortunately, I didn't push the reasons for this, I just purchased a new factory version.
Old Aug 20, 2020 | 09:35 PM
Pulse_GTO's Avatar
Could be a blown head gasket. Do a hydrocarbon test on the coolant expansion tank and a compression test.
Old Aug 20, 2020 | 10:53 PM
Danspeed1's Avatar
This doesn't surprise me and I have been suspecting this since the issue started. I hate to replace this thing again if I do not have to, but it might be worth it. The radiator is new, and it is large but it looks poorly made.
Old Aug 20, 2020 | 10:55 PM
Danspeed1's Avatar
So I did a pressure test on the cooling system itself and it didn't leak down into the engine. I do not have cats and my exhaust doesn't smell sweet. I am going to look into a hydrocarbon test, that sounds like a good way to put my mind at ease or find the problem. Thanks!
Old Aug 21, 2020 | 03:08 AM
Launch's Avatar
I've seen the red coolant that GM used after it has been sitting in an engine for a few years that had sat there not being driven, it had turned to a sludge in the block, to the point it had blocked some coolant holes in the deck. You should flush out the entire system, empty coolant, fill with water, get it up to temp hold revs at 2-3k for a few minutes. Let it cool, empty, repeat once again. Put water only in it again as go for a decent drive.. see what the result is then.
Old Aug 21, 2020 | 01:13 PM
ss1129's Avatar
My question would be, are you sure the coolant is flowing? If its flowing then I would buy some coolant flush or dawn and run some cycles of draining / refilling.
Old Aug 21, 2020 | 09:06 PM
Danspeed1's Avatar
So the good news is that I purchased the hydrocarbon test kit today and did the test... I do not have a blown head gasket or cracked cylinder wall. I am very relieved. So to begin I started throwing parts at it. I ordered a 20psi overflow cap, which will be in tomorrow.
I agree, it might be a good idea to do a coolant super flush. At this point there is some sort of stupid issue. I am seriously also considering ordering a different radiator.
Regardless, heads will be coming off in the fall, but I really would like to use the car before that...
Old Aug 26, 2020 | 07:49 AM
Danspeed1's Avatar
Coolant has been flushed and is still overheating. I am wondering if the ebay radiator is the issue. I hate throwing parts at things; this is ridiculous.
Old Sep 2, 2020 | 04:42 PM
00pooterSS's Avatar
Most likely a radiator issue since it only happens when driving.
Old Sep 2, 2020 | 04:44 PM
00pooterSS's Avatar
Higher pressure cap will only help if it's boiling over and you want to increase the boiling point. (the higher the pressure the higher the boiling point)
I would suspect the radiator since it does it while driving.
