Cold start rattle
Old Sep 8, 2020 | 10:03 AM
greaseman69's Avatar
Default Cold start rattle
Ever since I money shifted my car 3-2 I've heard this a rattle only on cold starts that sounds like you're shaking some nuts and bolts around in a tin can back and forth. I wouldn't describe it as a tick at all. I made a thread similar to this a few months ago but I dont think I mentioned the rattle and I've decided to stop being lazy and fix it. I used to think there was a loss of power but now I'm not sure if it was just in my head or not. I replaced my pushrods even though they didnt look bent, and the valve springs seem fine. My first thoughts were lifters or valves but on another forum someone thought for sure I blew an exhaust header gasket. Could this produce the same sound? Theres also a fairly loud hissing noise from the engine but that may be an unrelated issue that was there previously. 2000 trans am
Old Sep 8, 2020 | 10:17 AM
Cracked piston?
Old Sep 8, 2020 | 10:20 AM
Originally Posted by G Atsma
Cracked piston?
I forgot to mention this but I did perform a compression test and the numbers were near perfect. Cracked piston would screw that up pretty bad wouldn't it?
Old Sep 8, 2020 | 11:56 AM
Not if it's a cracked skirt, where it would not compromise compression.
Old Sep 8, 2020 | 01:52 PM
hmm. Dont you think if it were bad enough to rattle about 5 months ago it would have snapped off by now? The car is a daily driver and it doesnt seem like the rattle has gotten worse.
Old Sep 8, 2020 | 02:36 PM
I don't think there is any way to predict that. It might have cracked far enough to relieve whatever stress riser came up, and hasn't gone further... much...
Old Sep 8, 2020 | 03:41 PM
I don't think there is any way top predict that. It might have cracked far enough to relieve whatever stress riser came up, and hasn't gone further... much...
well as far as I know theres no real way to check so I guess I just have to hope it doesn't get worse if that's the case. If something does happen it'll be a happy little excuse for an LS3 swap haha...
Old Sep 8, 2020 | 07:59 PM
Doing a little poking around my engine bay I noticed my crank pulley has a bit of a wobble to it. It's a little hard to hear over the exhaust and my car was warm so it wasnt very pronounced but it sounded like a slight rattle around that area? Could a wobbling crank pulley make a noticeable vibration and rattle on cold starts? Something to do with thermal expansion?
Old Sep 8, 2020 | 09:22 PM
It most certainly can!
Old Sep 9, 2020 | 07:34 AM
That would be a much nicer thing to fix than a cracked piston. I'll start with that then, thanks.
Old Sep 9, 2020 | 10:13 PM
Actually, I'm now almost sure it's piston slap. Sounds very similar to this video:
Seems bad that it would only occur after an over-rev, but I guess I'm not too worried if it goes away after 10 seconds or so. Might try thicker oil
Old Sep 9, 2020 | 10:28 PM
pdxmotorhead's Avatar
bore scope? thay are pretty cheap these days...
Old Sep 10, 2020 | 02:58 PM
Blownbayou's Avatar
Not sure if thicker oil will fix that...... The top half of your piston never sees oil, so I would think oil viscosity would not make a difference. With that being said.... I have tried the euro blend 0W40 Castrol syn oil and I still get the slap, but it is not as loud,
So who the hell knows
Old Sep 15, 2020 | 10:33 PM
bad_408_vert's Avatar
Kind in same boat.
my car is a4 and I hit a bump causing car moving at 30mph to shift from drive to Neutral....im an idiot and had my hand close to shifter.
No negative besides similar noise and a hiss thats been there since before that.
Car just sounds quieter . Maybe because I switched from dumped duals to an actual catback
Butt dyno ofcourse is no help.
Does your exhaust seem low in volume too?
Old Sep 16, 2020 | 06:36 PM
Originally Posted by bad_408_vert
Kind in same boat.
I found that the hissing noise was a blown PCV hose, you probably also have a vacuum leak like I did. For some reason the rattle seems to have quieted down a lot. I dont think it's related at all but who knows...
