Motor mount vibs
The upshot is that it fixed the stiff shifter, but the shifter linkage developed a loud rattle which wasn't there before. The shifter is a one year old Sykke and works great. I've used many different shifters over the years on several different cars, but this is one is the best. The mounts are Oreillys from China for about $22 each. The Delcos were like $200. Any thoughts on this?? In otherwords, are there better mounts less expensive than the Delcos?? Please don't suggest poly mounts unless you know they don't vibrate. The reason I bought the rubber/hydraulic OE type mounts was to avoid the vibs. Thanks.
I was thinking that after the mount broke, the shifter or something might have gotten tweaked somehow, and once made right, the new tweak caused a vibration. Check it all over for anything "newly aligned". I would bet it is something along those lines...
