Air/Fuel Meter
Old Nov 9, 2020 | 10:39 AM
Mumbles's Avatar
Default Air/Fuel Meter
Hello all...
I recently installed a set of Texas Speed 1 7/8" Long Tube Headers on my '99 Formula. Well technically this is a test-fitting because I'll be removing them to be coated with a High Temp Finish at a local spray shop. However, prior to having them coated, I'd like to install an additional Bung for a Wideband O2 Sensor for an Air/Fuel Gauge.
I've done a few searches without a lot of definitive answers, so I'm posing this question.
Which Air/Fuel Meter and Wideband Oxygen Sensor Kit is deemed the best on the market?
This popped up first in my Google Search and appears to be a well put together kit.
https://www.aemelectronics.com/produ...ntroller-gauge
I have friends who have suggested this one. I like the idea of running two sensors to one gauge to monitor each bank.
https://www.innovatemotorsports.com/products/dlg1.php
Any suggestions would be welcomed. I would appreciate a link to where I can find what you're using and a brief explanation why you like or dislike it.
Thank you very much.
Old Nov 9, 2020 | 02:06 PM
98cherrySS's Avatar
Innovations works well and they have their own data logger software. They can also be incorporated into HP tuners via math channel I believe.
Old Nov 9, 2020 | 06:33 PM
Mumbles's Avatar
Thanks 98cherrySS. I have the Innovate Motorsports piece in my Amazon Cart and will most likely be pulling the trigger on it in the next 24 hours. Thanks for posting.
Old Nov 11, 2020 | 05:50 PM
VandykeT/A's Avatar
I use an AEM 30-0300X. Display will show 2 digits past the decimal point or 1 in AFR or will display in lamba. I use it for tuning but I have another older model married in my car for the last 8 years and haven’t ate a sensor yet.
Old Nov 14, 2020 | 06:43 AM
Mumbles's Avatar
Sounds like the AEM Unit is a quality piece that is both versatile and durable. Its good to know that there is more than just one brand that will do the job its intended to do. Thanks for posting VandykeT/A.
