Oil cooler line routing
Thanks! See the thread linked in my sig for additional build details if needed / desired.
Stock, the truck motors w oil coolers, run the lines along the block, right at the oil pan rail, and they exit to the front down low kinda between the PS pump and the crank damper. Their cooler of course is in the hot tank of the radiator, driver's side.
That little bolt just below the lines over toward the left goes to a bracket attached to the lines; if you use braided stainless lines, you could mount a clamp there.
The engine isn't in the car right now, but when I look at it, going up+rearward from the cooler adapter seems straightforward, and stays much farther away from the header primaries than running alongside the block. I have no actual experience here, so you're probably right.
I'm using a stock F-body pan on my LS3, but with Improved Racing's baffle and crank scraper. No Accusump or other provisions to guarantee pressure. LS3/L92 heads, which I'm told have better drainback than 241/243 heads. I'm feeling pretty good about not sucking air with this setup, but some people I've talked to tell me it's just a matter of time and I should have gone with a dry sump arrangement.
My budget didn't have room for dry sump. If I blow it up due to oil starvation, I'll use that as an excuse to upgrade to a forged rotating assembly, and do a dry sump at the same time.
The road course guys are occasionally going dry from g-forces. Nothing new there. Serious road course guys run at minimum an accusump to help this issue, and most run a true dry sump. HV pumps help get the oil to and through the cooler quicker, therefore reducing bearing temps and crank/rod temps also. The only downside to a HV pump is power loss due to windage and it takes more power to turn the pump, but we’re talking very little power loss that is unnoticeable to anyone but a dyno sheet.
I feel like I must be missing something. I'm under the impression that HV pumps are "for" engines with more components demanding an oil supply -- piston squirters, AFM/DOD, turbos, etc. I have not added any such things. The way I understand it, adding a cooler increases the length of the path, and the total system capacity, but the flow rate of the oil going into and out of the filter/cooler/t-stat circuit shouldn't change appreciably with the addition of an appropriately plumbed and spec'd cooler. You seem to be saying something different, and I'm not sure what to think.
I don't think I qualify as a "serious" road course guy -- I just do an HPDE a couple times each summer. Mostly, the car is street driven, but I definitely want it to be reliable and consistent on the track.
Why does a HV pump affect windage? Does the fact that I'm using a crank scraper (from Improved Racing) change anything? I'm expecting little to no windage losses thanks to the scraper. I'm not actually concerned about the potential power loss; just wanting to understand.
Your overthinking this. Basically if your going bigger cooler/longer lines than what the OEMs pump was designed for, you’ll need to go with a HV pump. The std volume pump simply isn’t designed to push the extra volume. The harder the pump has to work, the higher oil temps go. HV pumps have wider gears and are designed to handle more flow.
I've heard that gen3 LS heads have not-great drainback from the valve area that contributed to the problem. I'll take your word for it that they're better than SBCs -- no experience there. But I'm told that gen4 heads like the LS3/L92 set I have are better than gen3s in this regard, and so it's not something I need to worry about. You seem to be saying that gen3 and gen4 are roughly equivalent in terms of drainback efficiency? Please educate me.
I honestly can’t say that the gen 4 heads allow for more drainback capacity than a gen 3, but if there is a difference, it’s minimal. I haven’t noticed a difference in this area, from gen 3 to gen 4, but again, that’s something that I haven’t tested, nor seen tested.
For the record, I never had any oil pressure issues running my stock LS1 on the road course, but my G-forces were limited by street tires; the most I ever saw was about 1.3G, and that only for a couple seconds at a time. Any sustained Gs would have been in the 0.9-1.1 range. I'm likely to move to a stickier tire in the future, so I expect that to change.
It’s great to see you using the car on a course, even a couple times a year. Good on you man!
Getting the oil to and through the cooler quicker means a lower temperature delta across the cooler, all else being equal. I would think that a lower flow rate through the cooler would be preferable, assuming it's enough to keep the engine fed and pressurized.
The Improved coolers are designed to control oil temps, even at high flow rates. I’ve tested a lot of oil coolers (and studied the flow data of many others) and Improved coolers are as good or better than anything out there that I’ve found.
In my case I have a DART LS SHP NEXT 427 block. DART explicitly told me not to run a high volume pump because of the priority oiling system.
I have a standard volume standard pressure pump.
I haven't run the car yet with the cooler but I was going to in spring.
P.S. I ran my pan dry on an LT1 with a high volume pump.
