Knock sensor codes after header and motor mount install
Old Jan 5, 2021 | 02:24 PM
xny1989's Avatar
Default Knock sensor codes after header and motor mount install
Curious if this has happened to anyone. After replacing stock exhaust with headers and off-road Y, as well as motor and trans mounts, I've received the dreaded 327 and 332 codes. After some research, it appears that the knock sensors are now reacting to different engine harmonics causing them to read low and setting the codes. Curious to see if this is common.
Old Jan 19, 2021 | 04:00 PM
xny1989's Avatar
problem solved. Turns out that I I had inadvertently cut the two knock sensor wires on the harness side. Had to tap into the correct wires at the PCM and re-wired. Car started right up and no codes after second start.
