Trans wire harness too close to exhaust ?
Old Jan 14, 2021 | 07:49 AM
miles4's Avatar
Default Trans wire harness too close to exhaust ?
I have to flatten exhaust pipe that runs along my 4l80e just to install the plug in harness on drivers side of trans. I think I need to block heat coming from pipe to harness ... prob 1/2” clearance. Is there a heat resistant pad that can be clamped to pipe? Or am I better off using header wrap in that spot ? I think I should cover at least 1’ in length.
Old Jan 14, 2021 | 05:35 PM
I use DEI Heat Shroud around all my wiring close to exhaust systems. Cut to length with scissors and easy to install with Velcro. It’s a must have in my opinion. Works for fuel lines also.
Old Jan 16, 2021 | 10:06 AM
miles4's Avatar
Thanks. I’m going to give it a try
