Another exhaust thread! Question regarding '02 Z28 setup
I'm in the process of finalizing my Z28's (auto/2.73 gears) setup. It's going to be one of the following Speed Engineering setups:
- 1) LT Headers w/ True Duel Exhaust Setup (X-Pipe)
- 2) LT Headers with ORY mated to my factory stock exhaust setup (on the Z28 it's a single pipe to muffler with two tips)
As a third option I suppose I could take option 2, add a muffler and dump it, but as a convertible that sounds like it may have some consequences.
Thoughts? I really appreciate it.
EDIT: no emissions state!
True duals would flow best, but they are more expensive and will add weight. Will the extra hp make up for the added weight? Plus a fair number of guys install duals and then are not pleased with the increased noise level.
A good flowing muffler like a Hooker Maxflow (single outlet) or Hooker Aerochamber or Magnaflow (dual outlet) will give you some hp compared to stock, but won't cost a lot or add any weight. I like this option myself.
So are you suggesting that I go with Option 2, but instead of mating to my factor muffler/tips I remove that and instead install a new muffler? At that point I wonder what would be best for the tip situation? I suppose if it's ran all of the way to the end of the car I could either a) do a center outlet or b) dump it a bit before that. Thoughts?
I appreciate the help!
EDIT: for clarity sake, do we think retaining the stock muffler and tips would be extremely detrimental? Again I really like the look, I won't be able to copy that without doing true duels and then painting/powder coating those tips OR having something fabbed up which at that point will equal the true duel cost I'm sure.
For example, I have the stock tips on the Maxflows on my G8. Looking at it from the rear, you could never tell they're not the stock mufflers.
I've decided that I'm going to do LT>ORY>3" piping>Hooker Aerochamber Muffler>Tip
Given the reliability of electric cutouts, and the fact I'm located in MN, it just isn't a good long-term mix. Moreover let's be honest, it would be open all the time
