Dumb 5.3 Question
Old May 7, 2021 | 05:17 PM
devildogmech's Avatar
Default Dumb 5.3 Question
Dumb Question. When my 5.3 got delivered last fall, I noticed that the intake got banged around a bit. Turns out, the Retention clips for the MAP Sensor got snapped off and the sensor got busted.
I found sensors no problem, but cant seem to find the BUNG (for lack of a better term) that the sensor plugs into. It does look like a separate piece, but what do I know.
I can't seem to find an exploded diagram of the manifold...... Any ideas? I already had to replace a head, I don't want to replace the manifold unless I have to.
Thanks!!!
https://photos.app.goo.gl/yL8SNYKWFE3AsEPcA
Old May 7, 2021 | 05:52 PM
1FastBrick's Avatar
Thanks!!!
There are no parts availible for that. I am sure 1 tang will still hold it.
That bung that you are referring to is sonic welded on. It will not come off with out cutting it off.
Old May 7, 2021 | 06:38 PM
RedXray's Avatar
All you need is the bracket that holds the rear of truck cover (12561510) they are about $9 on e-Bay.
Or you can just fab a piece of metal to do the same job.
Attachment 712838
