Steam line routing
I want to tap the water pump for the line to exit, but don't know if I should bypass the throttle body housing.
This will be a street/strip 6.0 truck motor not running in cold weather.
If not, drill and tap the flat spot on top of the water pump. That area is a low pressure zone in the coolant system so it will pull water/bubbles from the steam ports and goes into circulation. Think I used 1/4" NPT with a barb fitting.
__________________
2013 Duramax / 2008 Tahoe PPV / 2008 STI / 2002 Z28
I wound up drilling the top of the water pump housing as above.
My lines are routed to make it uphill from the ports to the fitting on the hose.
Had no guidance just did what I thought looked good.. LOL
So far it seems to work.
It had the added benefit of letting me use a couple generic hoses to make the run from the engine to the radiator work..
