Exhaust brackets/braces snapping with cammed motor
im currently having issues with my custom over the axle duals which are basically a copy of the speed engineering system. For those familiar with the SE duals, there is a bracket/brace which joins the 2 pipes together where it rises up to go over the axle. As my motor is cammed and lopes a lot at idle, the exhaust shakes a bit and it keeps snapping the welds on that bracket. I had it redone and an extra bracket welded after the over the axle bend to try and take some stress away. Both of these have snapped today. The exhaust hangs on rubber hangers and has plenty of wobble so it’s not fixed solid so in theory shouldn’t be overly stressed on welds.. Anybody got any recommendation for me to stop this happening?
Have you checked your motor mounts? Excessive slop there could definitely cause issues.
There is also the possibility your axle is bumping it under hard compression.
