Leaking Injector O-Rings
I pulled the fuel rails out to replace the O-rings.. The rings are hard as rocks.. Brittle.. Breaking into pieces when trying to remove them. Also, the fuel rails literally lifted right out of the intake with very minimal pressure. I think I found the problem. Going back together with it now. Will re-set all the fuel trims and drive it to see what is going on with the STFT and LTFT's after this. Just one more thing I've never experienced before but it may help others. Based on the way the truck was running I would have sworn the IAC was bad.. But the fuel trims gave it away. The idle would hunt up and down, and up and down, and then eventually stall out even in park. I would stall intermittently as well just putting it into gear, but not every time. It was very confusing. But... I think I found my huckleberry.
I hope this post helps anyone who is chasing engine problems. Injector o-rings.. Just one more thing to check.
i am hoping to be able to get some advice from you since i am close to taking my used 5.3 block to them. I also am considering a mild cam. And wanted to see how you liked the one you put in your sons truck and any advice you had for my trip to the machine shop. I have a good idea of what i want them to do with the block but like most people i have a budget. My goal is to bring the engine back to stick condition, but use a mild cam. Any advice would be helpful.
Do you want the powerband higher in the rev range?
Do you mind losing some low end power?
If the answer to either or both the above is "no", you might not want too much of a cam, likely a cam like the BTR "Truck Torque" cam. 202/202, .511/.511, 111 + 1.
One area where there is power to be had throughout the range is a good multiangle valve job and bowl blend, aka pocket port.
If you have any more specific questions, please feel free to ask! Lots of good folk here.. It just sometimes takes a minute for some posts to catch wind before they sail!
I am swapping a 2000 5.3 with 862 heads into an 88 OBS. I plan on installing 2.5 -3 in exhaust true dual, x or h pipe. Id say I am just as interested in torque as I am hp, so street truck for sure.
As far as the cam goes I want to go as far as I can without having to buy a torque converter (not in the budget, yet) but I think my 862 heads wont let me, they may not be able to go with the flow. I have budget for either a head job, or I could find a used set of better flowing heads. I still need to do some research on the 862's, maybe a do what G said and do the valve and port job. I hoping that this will be a one shot deal, i dont want to be swapping cams in the future. Having said that I would consider swapping heads if the cam and the 862s dont work out.
I appreciate the insight on westside machine, I spoke with them yesterday and today I spoke with Houston Engine and Balancing. I might go with them, he's the first shop I spoke with that made sure to mention that he uses a torque plate when boring. Although, he charges about 100 more to use the torque plate than does westside. and btw i do plan on using the flats tops. But ill have to wait and see if i need a bore over, ive had two shops tell me getting pistons has been difficult these days, so getting an odd size flat top may not be easy.
G Atsma do you know a shop that does the "pocket porting?
As far as pistons, if flat tops are in the plan, just use stock 4.8L pistons in stock or whatever oversize you need. These should be easy to find, but w/ the COVID B/S maybe not so much
Where are you located?
Westside can source your pistons for you-they can get everything, or anything you need, right now.. Or, you can look here;
https://www.ebay.com/itm/27384474127...Cclp%3A2334524
For some reason i havent been able to send this post, i sent it once a few days back and it didnt go through, weird. I took my block to Westside this last friday. Phil, measured the bores and anticipated having to go .020 over. Hopefully they can get me some flat tops.
I finally buckled down and did research on cam selection, i appreciate the suggestions here, but the youtube video that really helped was from MyvintageIron, he had cam selection video, it really learned me allot.
I learned the most important things to me are drivability, It will live in low rpms as I will be in using the truck in the city as well as highway and I want good idle quality. I think you are right about the 862 heads, even though they are the "best" flow numbers i think with a little help and the right cam they will do just fine. The first choice im leaning to is a Howard cam with 114 LSA, here are the choices in order.Howard 216 int./224 exh. .551 int./0.551 exh 114
Trikflow 216 int./220 exh 0.560 int./0.560 exh. 114
Howard 218 int./218 exh. 0.604 int./0.604 exh. 113
You guys have any thoughts on these choices? They are very similar I know.
