NW 92MM Throttlebody install question
Old May 26, 2022 | 05:58 AM
AF1Strider's Avatar
Default NW 92MM Throttlebody install question
Hey guys. I installed a FAST 92 intake and NW 92 MM throttle body and have a question on the the throttle cable placement on the NW TB. Which hole is everyone running there TB cable in, the top or bottom one? I appreciate any assistance with this!
Old May 26, 2022 | 12:33 PM
brutalzo6's Avatar
I have the same set up and it’s on the top hole.
Old May 26, 2022 | 05:06 PM
LilJayV10's Avatar
I ran it on the bottom hole, using the top hole I couldn't get WOT.
My car has TCS, it might be different on a non TCS vehicle.
Old May 26, 2022 | 11:21 PM
brutalzo6's Avatar
Makes sense because my car doesn’t have traction control.
Old May 27, 2022 | 06:05 AM
AF1Strider's Avatar
Okay, Mine had TCS. However, when I tried bottom hole it was holding the blade open a little causing it to idle way to high. I believe I can adjust the cable length though. So I will have to move it to the bottom hole and try adjusting the cable length. I appreciate the input!
Old May 30, 2022 | 02:50 PM
LilJayV10's Avatar
Yup. There is quite a bit of adjustment with the TCS cables.
IIRC, there is one you are supposed to adjust first, but it's been so long I can't remember which one.
