Ls2 water pump issues
Old May 31, 2022 | 08:09 AM
Philhippy45's Avatar
Default Ls2 water pump issues
So I bought a ls2 water pump and housing as well as a thermostat that goes to a gto. My problem is that when I put the thermostat in the water pump and go to Tighten the housing I can feel resistance from the thermostat spring opening. So I tried taking it off and I can push by hand and feel the spring opening. Is that normal? I tried 2 new housing from autozone and Amazon as well as three different brands of thermostats (duralast,fail safe and one other can't remember). My ls1 nor the 3.8 in my pontiac ever did this.
Old May 31, 2022 | 10:02 AM
SAPPER's Avatar
Never heard of anything like this. Most common problem was the diameter from the early Gen 3s. Now they all get replaced with the newer pump and t-stat.
Where did the pump itself come from?
Old May 31, 2022 | 10:10 AM
I got it from Amazon its an acdelco 252-826. I was reading somewhere on Google that some people had tension on the housing from the thermostat pushing against but I can't see any of that being normal.
Old May 31, 2022 | 01:06 PM
SAPPER's Avatar
I work at a dealer and replaced hundreds of pumps. never had a t-stat hit the housing.
Old May 31, 2022 | 01:07 PM
idk if it's hitting the housing I think what's happening is the thermostat itselfs hits the back of the water pump causing the thermostat to be slightly compressed (open)
Old May 31, 2022 | 01:36 PM
SAPPER's Avatar
Well, according to my stuff, that's the correct p/n for the AC Delco pump. The OE # for t-stat is 12600172. The interchange to Advance Auto is 524KT. We don't buy anything from Autozone at all.
Hope this helps and you figure it out.
Old May 31, 2022 | 01:38 PM
all that is what I put in it I looked at the box its an ac delco thermostat and acdelco pump. As for the neck I tried ict billet and duralast both were the same.
