How to test ignition coil?
Old Jul 6, 2022 | 03:39 AM
97camer's Avatar
Default How to test ignition coil?
Need to test a ignition coil on a 07 gmc classic 4.8, have a misfire code. Thanks
Old Jul 6, 2022 | 11:08 AM
Rich-L79's Avatar
If you have a misfire and suspect the coil, swap the suspected bad coil with one of the others and see if the misfire follows the suspected coil or if it stays in the same cylinder.
Old Jul 6, 2022 | 01:14 PM
If the coil isn’t firing, spark plug will be wet. Spark plugs always tell the truth.
