help at Wits end
Old Aug 7, 2022 | 01:40 PM
ronjax's Avatar
Default help at Wits end
Help I have a 77 el camino with a rebuilt lq9 / 799 heads / and stage 3 cam/ ls6 intake
my problem is the fuel coming to the engine has air foam in the line
she will start briefly than die. have changed the wire harness, changed the computer , changed engine was 5.3 same problem
replaced fuel pump twice injectors 3 times etc
if I squirt starting fluid in intake it will run for a few seconds
put fuel pressure gauge have 57 # pressure when I blead off the fuel from the gauge its white with air
pushing on the shrader valve foamy gas comes out.
the pump is external
changed pump and put a gas line straight into the gas can........same thing starts briefly then dies
don't know where to go or what to do
Old Aug 7, 2022 | 04:41 PM
NoGo's Avatar
It sounds like a leak in the suction side of the fuel pump. As a test can you run a temporary line from a gas can to the suction side of your fuel pump and see if the problem comes up?
Old Aug 7, 2022 | 09:23 PM
pdxmotorhead's Avatar
Its sucking air between the pump and tank. This used to be common in the old mechanical carb days.. often mistaken for vapor lock.
It can also be because your pump is over working and cavitating the fuel. which WILL happen more often on non return systems.
If your pump is > about 200 LPH,, there's a good chance.. When the over pressure relief opens its recirculating inside the pump overheating the fuel and causing it to out-gas violently.
Old Aug 8, 2022 | 02:31 AM
LLLosingit's Avatar
Probably not the problem but I didn't see it mentioned, You did have VATS removed from the computer didn't you?
Old Aug 8, 2022 | 12:57 PM
ronjax's Avatar
Default wits end
yes the ecm was flashed for standalone use both of them were
have tried putting a hose from the pump straight into a gas can same problem no difference
as for the pump being too big making for cavitating could be the problem
using a walbro gsl 392 pump
the problem is as soon as I start the cold engine it stops running even with the key still on start
Old Aug 9, 2022 | 07:13 AM
Old Buzzard's Avatar
Lightbulb
"changed pump and put a gas line straight into the gas can........same thing starts briefly then dies"
Old Aug 9, 2022 | 04:58 PM
Full Power's Avatar
Originally Posted by ronjax
Help ...
What did the fuel stream from RETURN LINE look like ?
Old Aug 9, 2022 | 09:32 PM
jetech's Avatar
Veteran: Air Force
are you running a return style fuel system?
